Can anyone verify for me if the pins between the interconnect cables are reversed between the main board and the auxiliary board -- meaning, the wire at pin #1 on the main board is supposed to be in pin #24 location on the auxiliary board?
The original cable and my new Bob Roberts replacement look identical, connector-wise, and the original Atari schematic seems to correlate they should be reversed (no detail of individual wires, just flipped numbers - see pic), but I just wanted to check here with someone before possibly screwing this up and maybe having an expensive repair as a result.
My concern would be that perhaps the Bob Roberts one was created with the edge connector reversed, and I should fix that before proceeding. His is colored wires, and my original is all-white, so it highlights this issue.
Help a paranoid guy out... thanks!
