tester007
I pulled the control panel off to do some work on it. There was a broken wire by the torpedo bulbs. I soldered it on, cleaned up other things and put panel on. When i started a game, i notice the score line was missing, as well as the line that says how many torpedos left. I reach into harness to undo a random ground wire i attached, and noticed harness was warm. Turned off game, removed panel and immediately saw i had soldered thd bulb ground to the 5v peg by accident. I unsoldered, and put on ground peg. Put panel back in, and it still doesnt show score or torpedos... UNTIL you shoot a ship, then score line appears. Torpedo line stays blank, until you fire a torpedo and then that line appears. After you get those lines to appear, they stay for duration of game. All other elements seem to be working fine. Any ideas?
