Steverd
After reading a bit on the Sense mod, is it basically:
On the back of J7
solder a wire:
between pins 3 and 6 and then
between pins 1 and 2
Is that it?
Sounds super easy!
Has anyone also replaced R29 or R30 with a 100ohm resistor instead of the normal 10ohm?
Thank you,
On the back of J7
solder a wire:
Is that it?
Sounds super easy!
Thank you,
