FS Parts: Atari San Francisco Rush Steering Motor Driver Board #055315-01 #33315102065
john2654
Donor 3 years: 2011, 2020, 2024
Rhinelander, Wisconsin
Atari San Francisco Rush or San Francisco Rush the Rock
Steering Motor Control Board
$OLD
Part Number: 055315-01
33315102065
Was in a box marked "Rush motor board", it looks almost new - at least not used.
I tested it and it is working fine, but read below.
The board appears to work fine during game play, but when the system first tests the wheel, it goes in one direction normal and the other way a little slower. I think this is because there is a damaged part (C33). I attempted to soldered it back together, but replacing it might return the board to 100% function.
Actual item pictured.
I received another board and it works normally, so the issue was definitely with this board.
attachment.php
attachment.php
attachment.php
That's a deal for this board. The two little transistors that mount on the heat sink are worth more than that, and it's hard to find one of these boards that's tested working. If you have a San Francisco Rush, you should get this sucker NOW while you have the opportunity, so you'll have a backup for when yours shits the bed.
