mammyrat
I have an Atari Roadblasters. The left pedal has to be depressed very hard to operate and the right doesn't work at all. I have taken these things apart and they seem to have a pressure pad of some sort in the bottom with a little pile of sticky goo on top that I assume the pedal is supposed to press against the pressure pad and push the pedal back up when you release it. The pile of goo on both pedals has flattened out causing the problems. If I remove the pile of goo I can operate the game by pressing the pressure pad with my finger. What can be done to cure this problem? I thought of making a cone shape out of silicone caulk in a funnel and trying to trim it to the proper height. Would this work or is there another way?
