Atari PCB connetor terminal size
toolguy
Michigan
Can anyone please tell me the size of the termianls used for the Atari PCB connector edge?
Is it this size? .156" Trifurcon Crimp Terminals.
I checked Bobs site and did not see but found the connector edge repair kit. Funny how the kit is there but makes no mention of replacing the terminals in the connector, which in my case some don't look so good anymore. I also searched this site. Not listed in my manual either.
Thanks,
Thanks,
They are .156 Molex Split Pins, but they ARE NOT .156 Trifurcon Crimp Terminals.
Can anyone please tell me the size of the termianls used for the Atari PCB connector edge?,
Depends on what era atari... they used different types of edge connectors at different times, but anything pre-1980 or so (AMP connectors) should be replaced with molex .156 split pins :)
OK, I can see these are split pins and have gold edges. 79 Asteroids Cabaret...
Thought the plating was worn off but not the case, however some are pinched or kind of crushed, so I will replace all.
