atari monitor
pinjoe
princeton, West Virginia
Hi everyone, can anyone help me as I just got a Atari Kangaroo and everything seems to be working except monitor is burned in really bad and does not work at all, it there a replacement that I can use that will wire up fairly easy as I am not really firmilar with monitors as this is my first one. Any info or help will be great?
Well, my Kangaroo came with a Matsushita TM-202G. I replaced it with a K7000 I had handy.
You can replace it with any standard-resolution 19" arcade monitor. You may have to adapt the power connector if it's not the same, but the video connector should be the same....
