Atari/kee Tank II dimensions
Take II Dimensions
UPDATE: tdraghi has provided the exterior dimensions for the TANK II cabinet, which I have added to the drawing below. If anyone has anything they can add, that would be great.
Thanks, that would be great! I would like to add the height of the front, from the control panel to the ground. The height of the straight back section before it meets the angled portion, and I could also use the dimensions of the angled piece on the top back.
Front from CP to bottom = 31.5"
Angled top = 8.5"
Upper back (from to of the back door to angled top piece) = 8 5/8"
Back door = 31.5"
Lower rear = 9"
The rear panel is offset 1/2" or so from the bottom edge of the bottom panel.
Overall inside width = 23 3/4", so that's the width of everything.
All pieces are 3/4" thick, except the top, which is 1".
Thanks for the dimensions, they are a huge help. I have added them to the drawing.
Tank 11 dimensions
Tank 11 dimensions look up shark jaws flyer on the back side it gives all dimensions they used the same cabinet as shark jaws for tank 11 pal
