Atari Football with 2 1/4" trakball?
Atari Force
Altoona, Iowa
Does anyone know if it is possible to use a 2 1/4" trakball for Atari Football? I have a Football board and I'm trying to get to work with a small trackball and it doesn't seem to work. The board is fulling working so it's not a board issue.
Thanks,
Brian
Its probably because the 2-1/4" TB is using a different optic circuit than the original TB. Not all trackballs use the same setup.
cheers
/Tim
Interesting question - not sure I know the answer, but the 2 1/4" and 4 1/2" Missile Command TBs are inter-changeable. Is it a Missile Command 2 1/4" you are trying, or some other TB?
It's not a trakball from a Missile Command. I have a newer 2 1/4" trackball from happ controls.
-Brian
