andys80s Well-known member VAPS Joined Sep 22, 2010 Messages 1,141 Reaction score 32 Nov 17, 2010 #1 Can I make this swap? Just change the pinouts around?
OP OP andys80s Well-known member VAPS Joined Sep 22, 2010 Messages 1,141 Reaction score 32 Nov 18, 2010 #2 The Disco just has 1 ground wire....do I just split this to the 2 on the WG?
smalltownguy2 Well-known member Donor 2013 VAPS Joined Dec 30, 2008 Messages 17,076 Reaction score 2,650 Location Osceola, Wisconsin Nov 18, 2010 #3 I'm confused - are you trying to put a Disco chassis on a tube from a WG 4900? Or a 4900 chassis on a tube from a Disco? They DO use the same tube AFIK, but why are you swapping?
OP OP andys80s Well-known member VAPS Joined Sep 22, 2010 Messages 1,141 Reaction score 32 Nov 18, 2010 #4 I am trying to stick a WG monitor in a Gauntlet (2 player cab) that had a Disco monitor in it.
smalltownguy2 Well-known member Donor 2013 VAPS Joined Dec 30, 2008 Messages 17,076 Reaction score 2,650 Location Osceola, Wisconsin Nov 18, 2010 #5 Aha...got it. Should be easy, AC plug, Earth Ground, video feed. What was the issue you were running into?
OP OP andys80s Well-known member VAPS Joined Sep 22, 2010 Messages 1,141 Reaction score 32 Nov 18, 2010 #6 Thanks for the help....thought that there was the 6 pin and 3 pin needing to be plugged in....turns out I only needed the 6 and it plugged right in! Works fine. Last edited: Nov 18, 2010
smalltownguy2 Well-known member Donor 2013 VAPS Joined Dec 30, 2008 Messages 17,076 Reaction score 2,650 Location Osceola, Wisconsin Mar 10, 2011 #7 What did you do with the Disco monitor chassis? I may have a use for it if you're scrapping it.
