Atari Black/ White Vinyl Finish
Phetishboy
Avon, Minnesota
Would you lean toward Gloss or Matte? Please choose one or the other, as they are my only options in laminate. At first I thought matte, but the more I think about it, the finishes seem a bit shinier than thatte.
No way I'd do gloss. I've used matte black Formica laminate on a panel that was originally the laminated vinyl and my eye could barely tell a difference in sheen.
Fellow Minnesotan here. You have a local source for laminate? I may need white for a Dig Dug.
You won't want my opinion on laminate finish, I have no first hand experience with either.
Laminates
Hohldahl in Plymouth is the place to get vertical grade laminate.
You can call in and pick it up at the will call door. It's just past the Home Depot.
What did you end up going with, I know this is a little old?
