Atari Backlit Start Buttons (NOT RED)
So, just remove the 5 electrical connections and then how does the button pop out of the control panel?
Once you have the assembly out, I assume you take apart the back side next somehow?
#44 bulbs in there somewhere?
I have a Lemans and a Stunt Cycle and I actually didn't know my lights were out until watching YOUR channel!!!
P.S. My young son and I watch your Sprint 2 video nearly daily. We'll try to find one soon.
Thanks I'm glad you like the videos I need to get back into it and make some more.
Stunt Cycle and Le-mans should both have the style that you pictured above. To remove the bulb you don't have to remove the switch from the control panel or disconnect the wire. See the three metal contacts that are closest to us in the picture the two outer ones hold down the bulb as well as supply power if you remove the screw holding it down you can move the metal contact and the bulb will come out. They are miniature bulbs #328. If you do decide to remove the switch from the control panel then remove all wires (note where the go) and looking at the bottom of the switch you will notice 4 small screws around the edge of the switch remove them then you can remove the top ring from the bottom switch.
Awesome! Thank you so much for the guidance. Just ordered some 328's. Can't wait to fix a problem that I didn't even know I had! Thank you again and more videos please!
