Atari ARII voltage drop (Pole Position) [SOLVED]
rogerxy
Donor 2016, 2018
VGot, Sweden
Hi
My newly recapped ARII pcb (sense modded since before) to Pole Position gives +5V fine when no game pcb is connected. When I plug in the game pcb the voltage drops to 0,8V though.
This didn't happen before the recap so I suspect that it's something fishy with the AR card. Are there any usual suspects/components that is usually the culprit in cases like this?
Thank you very much in advance
/Roger
Hmm, it was changed together with the recap, but perhaps I got a faulty one...
Will try to change it again, thank you very much for the tips :)
This is what my transistor looks like. Was included in a rebuild kit
I changed the 2N3055 to a new one & now it seems to work, thank you very much :D
It might have been bad or I did something wrong when installing it that made it go bad when powering up
