Atari ARII sound - should I jumper these wires?
MadocOwain
Donor 2014
Greenwood, Indiana
Hi,
I'm playing with my Gravitar and the sound is coming across sounding like it's varying in volume. I've narrowed this down to a connection/wiring issue, and found that jumpering the ARII-04's P8 pin 3 white (spkr 2) to P8 pin 2 green (speaker return/speaker ground) would make the sound normalize. However, I do not want to fry anything in my boardset so rather than make that a permanent solution, or re-wiring the cab entirely, can someone tell me what effect that would have on the game and AR-II boards to leave it like that?
Before hitting reply and saying to swap out <component x>, I have done the following:
1. Swapped ARII, Gravitar board, and transformer assembly for known good Space Duel components, no effect.
2. Tried testing with speakers swapped for known good 4 and 8 ohm, no effect
3. Disconnected all speakers, monitor, control panel, volume/test assembly, coin door, and wired speaker directly into ARII, no effect
4. Speaker hooked to test leads on ARII = good
I cannot QUITE swap out the complete harness with Space Duel as P8 and another connector are wired differently for Gravitar than Space Duel.
Thanks!
Hi,
Thanks!
I would say fix the problem, not the symptom.
Hence, my post here asking for help understanding the problem.
Sorry was replying more to the tittle rather then what I actually quoted.
If you hook the speaker directly up to the test leads and it works fine, I would say you have an issue with the connector since the test leads are between the connector and the circuit. Maybe they are not making very good contact.
