Atari and Omega Race. Help
Braido
California
Can I put a GO 5 from a Battlezone in my Midway Omega Race cabinet? Are the pinouts the same on the connector? Can I just plug it right on?
The tubes are compat.
There would be a way to make it work, but not sure if it's plug an play etc.
I am soon going down a similar road but in reverse as I try to get my battlezone going
The pinout for monitor plug on an Asteroids DLX (which is the same for Battlezone) is:
Pins 1,2,3 - 10.6VDC, Pins 4,5 - Ground, Pins 6,7 - 36 VAC CT, Pins 8,9 - 6.1 VAC, Pins 10,11,12 - 60VAC CT, Pins 13,14,15 - 60 VAC
If Omega Race matches you are in business! I am just going to GUESS that the monitors are interchangeable.
I KNOW they are interchangeable because I pulled one out of my brothers Omega Race cabaret to repair and tested it in a Battlezone. It was plug and play interchangeable (unless someone repined the connector before he got it, which I doubt). I am assuming the other models (upright, cockpit and cocktail) would all be the same as well.
I Am getting spot killer on the game now. I wonder if a switcher would work?
Can some one tell me* if* that**LED* on* the* mother* board* is* supposed* to* be* lit* when* the* 5 V* is* present? Need help in* determining* if* the* power* supply* is* working* or* not.*
Has anyone put a switcher power supply in one?
