Astroroids Deluxe Problem
jarnold007_1
Fishers, Indiana
My astroroids deluxe took a little hit when a buddy dropped his end and now I only get the heads up stars background when I turn it on. Could this be a board problem?
Better open it up and see if everythings still intact, I dropped mine off of the handtruck once and the pcb went flying around inside the cab, got lucky and everything was ok once I reseated the edge connector and checked all the other connections.
Did that board seems to be in place will take it out and reseat it see if that doesn't work! If not what should I do then?
Sounds like the blacklight and marquee lights are coming on, your going to have to start checking for power to your monitor and pcb from the power supply in the bottom, check all your fuses and the holder itself.
Ouch. If it was a hard hit, it could have taken down anything. Did the picture tube of the monitor survive intact?
Where are you located? It might be easier for a member here to check out your game in person if you're not experienced with electronics..
