Astro Fighter Faulty Cocktail Cab
Were you pointing out in the video that connector G was not hooked to anything ? There should be a normal edge connector going to the top of one of the pcb's,,and on the bottom of the cage is a smaller connector.make sure both of those are plugged in,also i would remove the boards and put them back in..
You say you checked the obvious stuff,have you checked the voltages,i believe this set uses +5 +12 and -5.
Don
i assume this was the one that was sold on ebay the other day.if you have not grabbed the manual for the cocktail off the net do so,seems to me you dont know a great deal about them.
are you another another take the dive cab buyer?
also check the voltages first for a cab,if the voltages are not right the cab wont work right/correctly.
Thanks for the help. I printed a manual off today, and I will have another go at it
where will i be able to look to see if the voltages are correct (you guessed it im very new to this)
the only other machine i have is a batman forever pinball machine and luckly i've never had to do anymore work on it other than change a couple switches and bulbs!
