gsrogers Well-known member Donor 2023-2024 VAPS Joined Apr 25, 2007 Messages 6,398 Reaction score 1,108 Location Friendswood, Texas Jun 15, 2010 #1 Will a Centipede power brick assembly work in an Asteroids? Thanks
r5g Active member Joined Sep 26, 2005 Messages 3,833 Reaction score 14 Location Nevada Jun 15, 2010 #2 brik no there are diff voltages for the xy monitor in the asteroid brik vs centipede brik
HudsonArcade Well-known member VAPS Joined Aug 12, 2009 Messages 14,717 Reaction score 3,619 Location 01749, Massachusetts Jun 15, 2010 #3 gsrogers said: Will a Centipede power brick assembly work in an Asteroids? Click to expand... If you rewire the 15-pin plug, yes.
bit_slicer New member Joined Oct 17, 2007 Messages 2,984 Reaction score 17 Location Florida Jun 15, 2010 #4 HudsonArcade said: If you rewire the 15-pin plug, yes. Click to expand... Looks like it. Copying from my spreadsheet. Pins are numbered: J5-1 J5-2 J5-3 J5-4 J5-5 J5-6 J5-7 J5-8 J5-9 J5-10 J5-11 J5-12 J5-13 J5-14 J5-15 Asteroids: A034561 (B) 10.3VDC 10.3VDC 10.3VDC GND GND 36VAC 36VAC 6.3VAC 6.3VAC N/C 65VAC 65VAC Center Tap 65VAC N/C Chassis GND Centipede: 037669-01(A) 10.6VDC 10.6VDC 10.6VDC GND GND 36VAC 36VAC 6.1VAC(Key) 6.1VAC 60VAC 60VAC Center Tap 60VAC 60VAC 60VAC Center Tap 60VAC Last edited: Jun 15, 2010
