SaminVA
Ok here we go again. I almost hate to ask as this has been asked many times and yes I think I have read every post on this subject and still am unsure of the correct answer even if their is one.
First how loud should the sound be on Asteroids if you have the volume control turned wide open? Mine is not all that loud and has a slight hum or buzz. Back in 2001 when I first got this game running I could have swore the volume would blow you ear drums out if you turned it all the way up. Back then I had the audio hum but a new Big Blue helped lower the hum. I had this game stored in my garage for 6 or 7 years and just moved it back into the game room where I discovered I had a board problem. I sent the board off to road.runner and he repaired the board and the game works great but has a slight hum and low volume.
So I got a new big blue from Bob Roberts, the new black ones, replaced it and still have the same hum and low volume so next I replaced all the cap's on the Audio/Regulator board again with the same results, hum and low volume. So what should I try next? Replace the 2 TDA 2002 audio amps? Which brings me to my next question. I have 2 new TDA 2002 amps and the ones on my A/R board have the gray insulators between the IC and the heat sink and is mounted with nylon screws. Bob Roberts web site states the 2 TDA 2002's have no insulators and use metal screws to hold them on the metal heat sink so which is the correct way? Here is a picture of mine and a picture I found on this site of the other way.
