Asteroids UR: hum getting louder
vintagegamer
Donor 2024
Bear, Delaware
Since I got my Asteroids in 2005, there has always been a slight 'hum' in the speaker that I've simply dealt with. I know many of them have it so it was never a big deal.
But recently, the hum is getting louder, to where it's getting annoying. Does that mean the PS is slowly on its way out?
Thanks Orion-
Nope, I've never done anything to the game other than put new buttons on the CP. She's been totally self-sufficient.
Start there, and while you're in there clean the edge connector on the board with a pink pencil eraser (on both sides).
If you have the cash you may want to consider getting the AR/I rebuild /cap kit from Bob when you order the big blue - that'll help a lot.
Is it possible that this is because the inner bindings in that big-ass transformer at the bottom of the cab are coming loose? Someone told me that once...
I know this much...
My AD had a bad hum, found a bad transistor on the AR/I and fixed it
My Asteroids kinda hums, and the wiring harness is just hanging inside. When I moved it around once, the hum got a lot better (went away), so a bad connection can cause it.
Big blues for that game are now literally 31 years old, so they're due for replacement.
Replacing big blue and capping the AR/I is fairly easy :)
Also I tried turning off the marquee light to see if it made a difference - it didn't.
