Asteroids to Lunar Lander control panel
I looked and waited but could not find a lunar lander control panel,so I am converting my asteroids panel over to a lunar lander control panel. Heres some pictures of the progress.
I put all the markings in
I'm curious where you got the dimensions for your markings. I've followed Dezbaz's work and they both turned out great.
I downloaded the stencil that Dezbaz provided but I'm not sure how to transfer that image to the Asteroids CP. But if someone is able to just use masking tape and draw the cutouts, I'd be anxious to find out if you could share your measurements.
I transferred to tape like this
NOTE: The stencil is under the tape
Did you like, take that file up to some local printers office to have it printed out at the correct size? My printer only does standard letter, like 8.5 x 11. And the part that has me a little confused is, where the slotted carriage bolts normally go, forming a square hole, it's my understanding that a punch press was used originally.
I drilled a pilot then filed the holes square.
The stencil is pieced together from A4 paper. I cut diagonal little diamonds out, where the lines were, to ensure correct size
ok here's the answers to your questions. Take a measurements like you see in this picture. transfer those numbers to your panel, put the overlay on top and line it up to your measurements. These measurement are from an original lunar lander control panel. So, once you have these measurements, and you have the overlay, then and trace out the rest of the cut-outs, thats it.
