cwstrong
My Asteroids PCB is experiencing a distorted 'thump' that sounds more like a static pop. I've replaced the caps as well as metered the components in the audio portion of the PCB and everything seems to check out (I have a working PCB that I've been using to compare voltages, etc.).
Has anyone experienced the same symptoms and found a solution? I'm assuming it has to be an IC elsewhere on the board.
Any advice would be appreciated. Thanks.
