Asteroids speaker hum
Shavenyak
Donor 2023
Sarasota, Florida
Is it common to have a loud hum from the speakers on this game? Mine's louder than the hum on my DK. Any way to reduce it?
It's not normal. You may have a bad connection (mine sometimes hummed until I re-pinned the edge connector). Or you may have a bad audio amplifier on the AR board.
While you are following the other suggestions, also check the audio connector on the AR. You might need to re-flow the solder joints. I've seen this cure the hum as well.
Bill
there should be a checklist of stuff for Asteroids hum.
i'd start with:
- cap/rebuild the AR; reflow any questionable solder. set voltage to +5 at the main PCB.
- check all resistors and diodes on the AR; i recently fixed a hum by replacing a bad diode.
- replace "big blue" capacitor.
- clean PCB edge connector.
- check molex connector pins. replace any suspect pins, especially on the edge connector molex.
- disconnect the marquee light, the monitor, and the coin door to eliminate them as suspects for bad grounds.
- recap the main PCB.
good luck!
i'd start with:
good luck!
All good suggestions but if none of them work you might have one or both audio amp chips bad. Make sure you have the correct A/R board.
It's easy to test, I unplugged the edge connector from my asteroids board, also unplugged the monitor, turned the volume pot all the way up then powered up the game. With power to the A/R board find the 2 pins on the harness edge connector for the sound inputs 1 and 2 and take a bare wire in hand and touch to input 1. you should hear a loud audio hum like the input of a guitar amp. Then touch audio input 2 and you should hear the same sound. In my case one was loud and one was not. One of the Amps was bad so I replaced both. The audio amps are set up in a push pull configuration and if one amp is bad this causes an imbalance which induces the hum. That's what worked for me.
I took the liberty of re-ordering your list (roughly from easiest to most difficult) and adding amplifier replacment...
- replace TDA2002 amplifer ICs on AR board (TDA2003 can be substituted)
