andrewb
Yes, that is a speed mod board.
I'd remove it, at least for now, until you fix the other issues. Just remove and reinsert a 161 into C5, and the board should be back to stock. You want to remove any other potential variables when you're trying to debug.
There are also easier ways to speed mod these, without needing a daughterboard. Advanced Thread Search post bodies here for 'NMI mod' for more info. Though that board probably gives you more options, if you actually want to change the speed.
Also, I would replace that 161 at D7. That's a Signetics chip, and it's in the Vector Timer. It actually might fix your problem. But even if it doesn't, it's still an improvement to the board, because Signetics chips are such common failures. So you're just removing a weak point for the future, regardless.
