dochowl
Nearly complete but non-working Asteroids. Cabinet is in pretty good condition considering its age. Power block and AR work. No board is included, but I can include a non-working board for $40 if you want it.
Monitor is a G05-801. So when I got it the monitor was non-working. Someone had repaired a smoked resistor at some point. I went through and reflowed all the connectors. Plugged it in with a working boardset and the game worked great. About 20 minutes later one of the 470uf 50v capacitors on the deflection board blew up. They were original so I replaced both. Worked well for another 15 minutes. Then one of the 2 big blue caps on the monitor blew up. Needless to say, the monitor needs work.
$160 in Torrance
$160 in Torrance
