buxtonore
When I turn on my Asteroids game the screen is blank. No game sounds when I coin it up.
Player 1, and 2 buttons are lit up, and The Spot Killer Led is lit. When this first happened I turned it off ,and on, and it worked for a while. A few weeks later it started resetting, and then went back to what it's doing now. I've tried 2 different boards, and have done A cap kit on the monitor. I checked all of the components in the the monitor. I also checked the fuses in both the A/C Power Supply ,and in the Monitor. I rebuilt the Audio Regulator board as well. Big Blue has been replaced, and when I measure the voltage on the board it's at 5.134. I also installed A new edge connector, and new pins thinking I had poor contact to the Main CPU. Does anyone have any ideas what could be causing the game not to work?
