Asteroids pcb, reg, harness &pwr brick $175 shipped
chris25810
lake elmo, Minnesota
This has been my test rig for the past few months and it's time for a new home. This is a main harness pulled from an upright asteroids, the interlocks, volume control are all still attached. Comes with the working power brick, working pcb and regulator. The power switch that is gone but other than that, you could toss it all into a machine, hook it up to your coin door/control panel and play. This was all pulled from a machine running a go5-801 monitor but will also work in later Asteroids machines that used a go5-802/19v2000, you'll simply need to buy the adapter harness from bob roberts for $15 Send a pm if you want it all.
