Asteroids manual info.
Reddogg
Upland, California
I'm trying to wire in a volume control pot, and a test switch into my Asteroids, but I'm not sure exactly how. When checking the manual, on figure 19, the main harness and component assembly diagram, there are a bunch of abbreviations, and I'm not sure what they mean. Does anyone know?
Thanks.
It should show the test switch and volume pot pretty clearly - the little letter abbreviations you see are the colors of the wiring. That said - take it with a grain of salt, as white wiring kinda ages after 31 years. Since I just looked at it recently I can tell you the test switch I believe are the wires that look black and white, not sure on the other two although I can get you a pic tomorrow if you want.
BK - black wire
W - white wire
NC - normally closed switch position
NO - normally open switch position
BN - brown wire
W/BN - White wire with brown striping
BK - black wire
W - white wire
BN - brown wire
NCOBIHU - Normally cut off by ignorant home user
Cool.
I figured wire color, but the nc and no were throwing me off (still learning).
Thanks everyone!
C on a switch is common
I was working on this yesterday, open (NO) is Game mode, and closed (NC) is test mode
