7146aaron
XY
Not always true.
Just because it is playing blind DOES NOT mean there is video coming out of the board. You can use a simple volt meter to check the xy swings to see if it is putting out video if you cannot figure out your scope. Could be a board issue, monitor, connector issue or all 3.. After you check to see if you have video comong out of the board. If you dont have any. Try reseating the socketed chips on the game PCB to see if anything changes. If you do have video out of the board, Reflow the headder pins on the monitors deflection PCB. Common failure point.
If you have normal game sounds when play is pressed it is playing blind. If it is playing blind, you have a monitor issue.
Not always true.
