Asteroids High Score Save
wraywray
Donor 2015
Bedford, Indiana
my saved scores have mostly disappeared. only the one now appears. while playing the games plays perfect with nothing disappearing. has anyone ran across this before?
ok removed the kit and high score screen is there. so it must be something on the braze kit. which chip on the kit would be the one responsible?
Is this a new pcb to you and a new kit to you?
Are you running the v2 rom from the kit in pcb?, this is additional to the kit itself.
The binAries on the kit are on the 256k chip. Not much you can change out.
How about resetting the high score table?
Settings on kit for score table?
No had it 2 years on the board. Yes the v2 rom is installed. Worked perfectly until the week. I seen some chips were socket so I thought I would be lucky and able to swap out one. Settings are on free play. Every thing was factory settings as I installed and played
QUOTE=HighScoreSaves;3523060]Is this a new pcb to you and a new kit to you?
Settings on kit for score table?[/QUOTE]
http://www.brasington.org/arcade/products/hs/asteroids/trouble.shtml
As Andrewb said it could be the eeprom.
You might try to reseat the chip..
You might try to erase the high score..how is in the link above.
You might contact the website and see if they can help.
If those don't work you might want to buy a new chip and see if that works.
