Asteroids Flicker Video
nanoryan
Washington
Hey guys,
My Asteroids starts to flicker after it has been on for a while. The flicker goes from the bottom to the top. Monitor is a Wells G05-802. Any suggestions for what might be causing it? It works great except for this issue. Below is a video.
http://www.youtube.com/watch?v=1kLvKSIcMTs
Thanks for any suggestions, Ryan
electrolytic capacitor is dried out and needs replacement. replace them all. while you are there with the boards out on the table, reflow any cold solder joints.
if problem is still there after above, start checking the pins inside the connectors for weakness and oxidation or both and replace them and clean the male ends too.
Thanks for the suggestions guys. I will try a new big blue and if that dosen't fix it ill do a cap kit. Always something! :)
