morphis72
Can you try the other monitor or deflection board that you have? That will be the fastest way to narrow it down.
So I didn't move the whole display.. The one in my Battlezone actually has some dot burn in and it's a bit of a pain to pull the monitor so I wasn't sure it was the best test. But, I did move the deflection board as asked and got the same results. It took about ten minutes and then the dot showed up. Went away after game ends and comes back when starting a new game. The tube in this asteroids is pretty cherry is why I am sweating this so hard....
If you think it is a good idea to move the other tube over I will but wondering at this point what you guys think?
