RobertBasil
Asteroids Deluxe x and y size adj monitor pots location?
They are supposed to be on the PCB and labeled, but I can't find them anywhere. I've also looked everywhere for a diagram layout of the PCB with no luck. Tried the manual but it does not even show the PCB.
Any help? Using the test mode I can see that the vertical setting on my monitor is stretched way to high.
Thanks!
Thanks!
