Asteroids Deluxe Vector problem..
mcandrewsoun
Fincastle, Virginia
I dont think this is the monitor.. I repaired the 4016 and TL082 in the X output section of the board.. The screen looks completely out of whack, both on the monitor and on the scope in xy mode. The images appear in a smaller scale..but fill the screen. I was thinking that there may be some bits missing on the DAC..but both DACs? Anyway, I put the game in test mode, and Im getting two small crosshatch grids.. Looking at the x and y outputs on the scope, theres a wierd shift from pos to neg at the sametime on x and y.. Anyone ever seen this before?
Fixed
After going through the tech manual, Since everything was in the correct spot (well mostly), just the wrong size...let me to the vector timing circuit. I was thinking the scaling lines were messed up, but they were all active.. finally checked the vector counters, and found the 161 was outputting all high. Couple of interesting notes.. I read somewhere to first check for "cool" chips. This one was noticeably cooler then the other 2 timers. Also it had been replaced fairly recently.. So I installed a socket..;-)
Andrew
Andrew
Great tip and I will file it in my troubleshooting list. The opposite is also true - <carefully> check for very hot chips. I bought an infrared thermometer cheap on clearance at Radio Shack and it has been helpful, especially if there are multiples of the same chip I can compare the temps. Quick and dirty yes but still no substitute for an oscilloscope or logic probe.
Bill
