Brick Top
This AD had a bad AR board when I picked it up (approx 12V). Fixed the AR, game worked, for like 5 minutes. Then it reset, and continues to reset.
Test mode looks fine. When I run the game it constantly resets, everything blinking. If I tie the "WD Disable" to ground, the game will run but the score is constantly blinking, and the bottom of the screen looks like 888888888 all the way across it. When those bastards that break up into small pieces come out they are also duplicated all the way across the screen.
High score screen looks fine in attract mode, I can even undo the WD disable, the game is fine until the asteroids attract screen, then it goes into reset loop again.
VIDEO here
Thanks for any help! I have a spare AD board that I can swap parts from for testing.
VIDEO here
