Asteroids Deluxe Monitor Query
Arcade1VA
Illinois
I have an Asteroids Deluxe cocktail that is fully working, but seems to have an issue with the monitor. The picture "jumps", in that it seems to start out a bit smaller than the outer edges of the tube, then jumps out to the full screen. Is this a sign of a transistor going south? I would like to replace the transistors, and any other suspect components that are known on this monitor. Anyone deal with this issue?
If you think this is a monitor issue, you should put it in the monitor section. Start with a rebuild kit and see where that takes you...
