Asteroids Deluxe Issues
NHRA21
Clinton, Connecticut
I just picked Asteroids Deluxe and it has some issues. When the machine is powered on, I get random lines on the screen. Every once in a while I will see the ship for a second, then it disapears. I also have mixed noise coming from the speakers. I check the power brick and the outputs seem to be correct. I also checked the outputs from the AR board and the +5 was a little high, so I backed it down. The second voltage was a couple of volts high, but I see no way to back that down. Also, the P1 light is solid and the P2 light is flashing. I can't get it to go into self test and it does not play blind. Any ideas? I should be able to take a video if needed.
