squall280
So i purchased a proper replacement for the balck light. I pulled out the lighting frame work to install the bulb. this has it so that two wires go on each side one wire to each pole, like i imagine it is suppose to be. i plugged it in and i got nothign on turn up other then both ends of the bulb having the faint glow as if it wants to turn on but doesn't. so in figured maybe i had a lose connection on one of the bulb poles and accidently knocked of one wire on just one side and it lit up. i proceeded to put the wire back on the bulb and it made it go back to where it wasn;t on and the neds were slightly glowing. any help?
