csa3d
The only way to know that for sure is to meter them. Does the manual specify what chip is bad for one beep ?
According to the manual:
However.. this page of the manual is printed WRONGLY because there are no ram chips at D2 nor E2... but rather at L2 and M2 (cross referencing the parts list of the same manual proves this).
So given that If I take out all but the first ram chip at L2, I get one high beep, one low beep.. I'd say Ram position 1 is working. When I put the second chip in M2 position, I get low beep low beep.. which is odd considering you are suppose to hear a high beep for every good ram which passes.
Also weird is that if I boot up the machin IN test mode, I hear only 1 low beep. If I then either hit the reset button or flip the test switch on and off again, I hear the tone patterns I describe above.
-csa
