csa3d
I am having troubles getting my asteroids cocktail cabinet up and running, and was hoping someone could help me with the next steps to take.
I've done following repairs thus far:
- Capped the main PCB, the AR-1, and both boards on the G05
- Replaced all fuses on all boards
- Did edge repair on the main PCB
- replaced all pins on the wiring harness
- replaced the AC plug because someone cut off the ground pin
I've ran a self test and I get only 1 low beep, and nothing more. I'm guessing this means it failed on the first RAM. According to the manual, this ram would be in position D2. My PCB appears to have never had a chip installed at this location (see attached image). What do I do from here? If I need to buy chips for the board, should I just buy all RAM/ROM chips ahead of time, assuming that others will be not working as well? Where do I get these from.
I've also run voltage tests on the power block using http://forums.arcade-museum.com/showthread.php?t=121666&highlight=test+power+supply+voltage&page=2 as a guide.
Here's my results:
Power Brick
Remove the big 15 pin connector P5
***V***V***
*1***2***3*
*4***5***6*
*7***8***9*
*10**11**12*
*13**14**15*
Meter set to 20vdc
Red lead to pins 1, 2, 3
Black lead to pins 4, 5
Reading should be 10.3 vdc (could read high 13vdc as it is unregulated)
reading: 14.15 (high)
Meter set to 200vac
Red lead to pin 6
Black lead to pin 7
Reading should be 36 vac
reading: 37.5 (high)
Meter set to 20vac
Red lead to pin 8
Black lead to pin 9
Reading should be 6.3vac
reading: 7.1 (high)
Meter set to 200vac
Red lead to pin 10
Black lead to Pin 14
Reading should be 80vac
*** No reading: My power supply has no pins in either spacer #10 nor #14 ***
Meter set to 200vac
Red lead to pin 11
Black lead to Pin 13
Reading should be 65vac
reading: 62.9 (low)
A/R I
Remove the 9 pin connector P7 (P5 on the power brick must be plugged back in)
__^__^__
*1**2**3*
*4**5**6*
*7**8**9*
Meter set to 20vdc
Red lead to pins 5, 6
Black lead to pins 1, 4
Reading should be +5vdc (could be as high as 7 or 8 vdc because there is no load)
reading: 6.3 (high)
Where do I need to adjust anything to tweak these values any?
-csa
EDIT: Link to my restoration thread here: http://forum.arcadecontrols.com/index.php?topic=94356.0
Here's my results:
Power Brick
***V***V***
*1***2***3*
*4***5***6*
*7***8***9*
*10**11**12*
*13**14**15*
Meter set to 20vdc
Meter set to 200vac
Red lead to pin 6
Black lead to pin 7
Meter set to 20vac
Red lead to pin 8
Black lead to pin 9
reading: 7.1 (high)
Meter set to 200vac
Red lead to pin 10
Meter set to 200vac
Red lead to pin 11
reading: 62.9 (low)
A/R I
__^__^__
*1**2**3*
*4**5**6*
*7**8**9*
Meter set to 20vdc
reading: 6.3 (high)
-csa
