Just a question.
My cab has been working fine, but recently when I turn it on, it keeps reseting the board. As-in I turn on the power and at first, my board will reset over and over(with beep), then be fine for a while, then it will reset again and again. At that time it would just reset the PCB but Now recently it's been reseting the WHOLE cab, as-in the coin mechs making there clicking sound over and over(like it's lose power to it and regaining it), the monitor display spot killer turns off and on(like when it's not getting a good signal from the PCB).
I've done a cap kit a couple months ago, replaced big blue about the same time. I've looked at the power supply and don't see any obvious problem. It's getting the voltages out that it's suppose to. The AR board is also putting out it's required voltage(just did a recap kit on it, not too long ago).
Do you think that the AR board is causing the problem, does the coin mechs work off of that board, which would explain why it's clicking off and on(losing it's 12v) when it resets.
Not sure where to go from here, PCB(cap kit done) seems to be ok, I just wonder if that AR is causing havoc or if the ISO is shitting out on me. What do you think?
I have gone over it and can't see any loose connections
Now keep in mind, I can't MAKE it reset, as in, if I wiggle wires or jiggle the cabinet, push buttons etc.., it will not reset. It just does it on its own. Sometimes constantly and sometimes once or twice every half hour.
