So I finally decided to start working on my Asteroids Cocktail table again. Last year I changed the connector plug to the PCB, because the original was badly corroded and in a bad shape. Back then I went for a non solder solution, and bought a connector and pins to crimp. Im not happy with the result and decided to buy a solder one instead.
But now I dont feel confident that all the connectors are in their right position. I have googled to find out the correct color coding for the wires, but i cant seem to find anything. I did find the normal pinout for the game, and the manual but since I dont know which color wire is what, it did not help much. I was hoping to double check that the wires are correct before soldering that bad boy.
So, I was hoping someone in here might have some kind of pinout for the 44 pin plug that also shows the colors? For the Asteroids Cocktail table?
