asteroids cabaret g05-805 image on monitor too large
security0001
Donor 6 years: 2020-2025
Montana
is there any adjustment to reduce the size of the image?? the image is too large vertically and horizontally. the score and number of ships is about off the screen. is it the linear x y pots on the deflection board or the game board x y axis pots or something else?? is there any voltage adjustments like the B+ on a non vector monitor that is overdriving the image on this vector monitor? thanks for any help.
Yeah,you should be able to adjust the pots on the game board to get the right size.You probably wont have to mess with the ones on the deflection board.
yes the y and x axis pots on the game board worked perfectly to reduce or enlarge the image to fit the screen properly. put the game in test mode first so you have the grid pattern to use.
