MitchO
So this is my first machine with a vector monitor (Asterioids w/ Electrohome G05-802 monitor) and naturally it has decide to act up. Hopefully the pictures kind of show what it is doing. The issues seems to happen somewhat randomly though it tends to be worse if there are a lot of things on the screen. If you can't tell the objects in the upper right hand side of the screen want to flatten out into a horizontal line. When it gets real bad the objects in the upper left and lower right will also display the same behavior.
Is this a case of it just needing a cap kit or is something else needed?
Thanks,
Mitch
Thanks,
Mitch
