wugly
I am having problems with my vmem output. it stays high for quite a long time. in excess of at least 2 seconds then I get a single pulse down. this is on chip e4 of address decoding circuitry. pin 14 input looks decent input on pin 13 looks to be pulsing but around 3 1/2 volts. should I pull pin 24 on cpu from socket and check the output or do you think e4 is bad. my output on e8 but labeled l8 on schematic or all looking funky half of them are stuck high with a few being high mostly with brief spikes to 0. pin 12 is the only input that looks bad and that percolates back to a7 with an input of vmem from e4.
pulled mpu and bent it and saw good 4 volts minimum on signal. put it back in and am seeing a lot of pulsing on pin 13 and 14 but a lot of time on a 5 volt signal with only a stray vmem going to 0 volt. a14 from mpu was probably dirty. but I am wondering maybe not having enough vmem pulses. any ideas?
