starfighter2
I am taking another look at my asteroids deluxe monitor display issue and thought I would start from scratch. I read a couple of articles and post about the voltages needed to goto the monitor via P100 and noticed very strange readings(I will post later, mesurments taken in test mode as articles suggested). I got this cab from someone else that could not fix it and so I am concirned that the wireing in not correct. So I would like to see if anyone has a diagram/article as to where the wires to p100 (to the monitor) come from. I know that they come from the board and the power block but from what pins to what pins? The monitor is a G05-802 version 5 board.
Second I did not see any 30 volts to P100 but the game seems to play blind. Wanted to find out what may be causing that?
The board seems to have the correct X and Y volts Z is 2 volts instead of the .9XX volts which others seemed to indicate that that would only increase the brighness.
Thanks in advance for any help.
