The black rubber rings that makes the joysticks hit the cherry switches are all gummy and broken. Are replacements available? I see the white plastic parts are available, but not this ring.
Not exactly, but you can use a flipper rubber ring as a perfectly servicable replacement. I used ones I had bought for a williams space shuttle, and if you search around the forums you can probably find that earlier thread with the specs.
