Asahi Coin Mech Switch
ddonaldson
Hammond, Indiana
I'm in search of a coin switch for an Asahi Coin Mech Model Number 740 (please see picture).
I have been searching for most of the morning, and while I found the orignal white paper on it, I could not find a replacement part.
I know I can contact Asahi directly for parts (like face plates and what not), but would they carry something like this? Is there an repoduction out there?
Thanks again everyone,
Dan
Bob Roberts carries this for $3.75, which should work as a replacement, although the mounting holes may be different:
Bob Roberts carries this for $3.75, which should work as a replacement:
The mounting holes are in the wrong corners.
You would have to drill new ones in the mech to use these if you are using a 730A mech. If you have the KWM-740 then there are extra mounting holes you should be able to use,the lugs will be pointing towards the door instead of down but it should work.
Here is a thread that might help. http://forums.arcade-museum.com/showthread.php?t=94055
You guys are great! Thanks alot...I'll see what Asahi charges cause i'd like to keep it original, but $3.75 is hard to pass up!
