Artic Thunder Power switch
Encom
Etters, Pennsylvania
I just picked up an Artic thunder and the power switch is broken on it. There doesn't seem to be a part number listed for it in the manual. Anyone know the part number or where to find a suitable replacement. It is one of the square rocker switches that is pressed into a square opening, so it has to be the same size and shape.
Rich
Thanks but that isn't the same one. The one I need is just the rocker switch it is around an inch square or so.
Pull the old one out, go to Radio Shack or some other electronic supply place, find one that fits (doesn't have to look exactly the same unless you're hyper-sensitive), put it in, and have fun...
I believe I have some these switches in my Midway NOS parts stash.
Let me take a look next time I'm down at my parts storage.
That is very close to it.
I though I would post what I found on them in case anyone else was looking for one. I found an almost exact replacement for it at Digikey. It is part number 360-1496-ND It is a DPST switch with a 8A/125V 16A/250V current / voltage rating. The only difference is that the new one from Digikey the button is black vs. the original one that is red. It is even the same manufacturer and Amperage ratings. They are 10.93 each.
Rich
