ArPiCade player 3 and player 4 controls
RiddledTV
Kansas
I'm interested in the best hardware interface (with instructions I can follow) to add player3 and 4 controls to my ArPiCade. I'd appreciate any suggestions or general pointings in the right direction.
I'm extremely novice in configuring in mame, retropi or anything linux related, so I really need to have something with basic instructions. I hope to find a way to play all the Konami 4player games and similar on the same setup and be able to make it kid friendly for use.
thanks in advance
I can't speak directly to arpicade, but I have a bit of experience with raspberry pi. My Ipacs runs great on my PC - and I can confirm the J-pac works with the Pi. But since your p1 and p2 controls run through the Arpicade, you could use and ipac2 to do p2 and p3, or use two easygets for p3 and p4 separately. I've used easygets for 2 mulitcades and they work just as well as my jpac, and Ipac2.
Once you install you should be able to map the controls directly in retroarch.
https://www.amazon.com/Easyget-Cont...e=UTF8&qid=1526335697&sr=8-9&keywords=easyget
I recall seeing a section on High Score Saves for an adapter or something.. Maybe something is in the works?
